What 718 EV drive train would you be most interest in?
Which 718 EV trim is most appealing?
  • Total voters
    23
Kakatus10
Kris
Arizona
Poverty Spec Taycan 4S 21'
Assuming all the following options are available, which drive train would you be most interested in?
Note, the Macan EV is 78k (+20k from ICE version), so trying to make prices somewhat realistic given Porsche tax and that it will be likely a Fall 2025 release date.
Personally I've always thought a dual motor RWD would be the most fun and interesting vehicle in terms of handling, with built in torque vectoring.
They won't make a tri motor, as they didn't in the taycan GT; a car costing close to 300.000 in some markets.
718 EV will have single motor, and maybe top of the line a dual motor.
Also, 300hp in a EV is a joke, much less in a 718. The Macan EV base starts at 402hp and its 75.000.
718 base will probably be around 450-500hp; with a turbo s reaching around 650-700.
We don't know what platform it will use, but Porsche said it's a new one ment to keep the car "light weight". We don't know what battery chemsitry they will use, but if they want it to be light weight the battery will have to be small, say 70kw max, and the car will have to be very efficent to each 200-250 miles minimum to be competitive.
Kakatus10
Kakatus10
Kris
Arizona
Realistically you're comparing a Macan that weighs over 1500lbs more. A 300 HP 3500 lb EV would do low 5s 0-60 easily.
However, I could see the Taycan motor setup would likely just be reused at 400 HP.
However, it'd be nice to see something bespoke.
Realistically it will likely a derated Taycan RWD motor due to a lower pack kW output. I estimate the base model will have 55-65 kwh pack.
Then an AWD model will weigh 500 lbs more with an 80kwh pack and AWD or something along those lines.
I am getting my hopes up for a dual motor EV RWD setup, I wonder who will be first to do it.
Personally, prefer RWD > AWD myself.
f1eng
Frank
Oxfordshire, UK
Taycan CT4S, Ferrari 355, Merc 500E, Prius PHV
Me too but AWD makes more sense in an EV for balanced regenerative braking, so I have changed my preference.
I had zero interest in AWD with IC engined cars though.
